I set up Tablo Connect, with Port forwarding correctly on my router. (Tablo settings look ok, and it says “Your Tablo is ready for remote access”.
When I try to access my tablo on my iPhone iOS app, I am unable to connect with my tablo.
Using my iOS device on my home wifi network, and when Re-scanning for Tablos, I DO pick up a tablo that is named “tablo-quad”, …but my actual Tablo is NOT named this.
When trying to connect to “tablo-quad” on my iOS device, it tries to connect, hangs, then says Connection could not be established.
If I use a wired computer connection to access my.tablotv.com, I am successfully able to “see” the correct Tablo-name and access my Tablo.
Any suggestions? thanks.
