Remote Access Authentication After Router Change?
The router in my residence (where my Tablo is) has been replaced. The local IP subnet is the same range, but the Tablo IP has changed. The WAN IP has also changed.
My vacation place has 4 Fire TV sticks with Tablo client app for remote streaming.
Is it going to be necessary to unhook and bring them to the primary residence to re-authenticate? I sure hope not.
Does anyone have any info about this?
Thanks!
I think so. You may want setup with a static IP address going forward eliminates a lot of issues.
Do you mean static IP on the WAN? That might be expensive.
I have already setup a reserved IP for Tablo on the LAN so that shouldn’t change again.
Thanks
