Recordings stop
My recordings freeze about 20 minutes into a program. Then the program restarts at the beginning. Every time
What are you using for a streaming device? Also, are you new to Tablo, or had it previously be working okay and this is a new problem?
I have had this Tablo a couple of years. This is a new issue
Also, I watch Tablo on a Roku device, or on an iPad. The same issue on each device
A few ideas:
  • hard drive may be failing
  • Tablo is overheating
  • Power supply failing
Does it freeze when watching Live TV?
General things to try, if you haven’t already: Reboot your Tablo, and also reboot your router. If that doesn’t solve it, clear the cache on your streaming device (see below for instructions on how to do this on various devices). If you still have a problem, I would delete the Tablo app from your streaming device, then reinstall it.
These are the first troubleshooting steps I always recommend, and they often solve a variety of issues.
