Recordings on my iphone will not transfer to the tv. Pressing the air tv icon doesn’t do anything.
I’m not sure what tv icon you are pressing. You need to set up Screen Mirroring on the iPhone. You do that with the iPhone settings. There is no need to do anything in the Tablo app.
Thanks for the advice. I decided to try the Tablo with the HDMI connection because my iPhone was having trouble finding the Tablo 4 Quad connected to the Ethernet even standing next to it. Maybe because I had to add ports and was getting the message a LAN was incorrect no matter how the lines were rearranged. It looks like the TV connected Tablo will work, but I do go on when I just wanted to say thanks for taking the time to respond.
