Recording wrong show
I’m having some issues where the incorrect show is being recorded. This is a consistent issue with The Simpsons. This appears to be an issue with the guide. Any suggestions?
@smurfier - Can you provide some more details? How are you setting the recording? Are you not getting the Simpsons? How is the guide wrong?
I’m setting the recordings by searching for a show then using the record button. It usually records either the show before or after the one I want. This only happens once in a while but always with The Simpsons.
I’d suggest touching base with support and providing as much detail as possible with specific examples. The air date, the network etc. There are a few different reasons why this might be happening and it’s not easy to understand why without additional data: http://support.tablotv.com/hc/en-us/requests/new
