I had a show scheduled for recording every new episode. Last week episode was recorded without problem. This week episode was recorded but without sound at all. I had other recordings done this week that had no problem.
What could be the cause? Anything I can do to prevent this from happening in the future?
@Onirike - Is the sound coming in fine on this channel now when you watch it live? Can you set a test recording on that same channel and see how it turns out?
It could be there was a temporary issue with the broadcast itself.
It might have been a broadcast problem. There was a re-run of the same episode on the same channel so I scheduled it for recording and it recorded fine with sound.
Thanks for the reply. I’ll let you know if the problem occurs again!
