Record show on multiple times
Laramie is on Grit several times per day, with each show being different. Grit just started broadcasting in Austin, TX on Jan 29, so there is no guide data. Is there an easy way to record all of them besides creating a manual recording for each time and selecting repeat? When the guide shows up (hope by Tuesday) then I can simply select Laramie record all and everything will just record.
