Hey @Davidvr,
I’m wondering if you ever modified your script, it no longer seems to function as intended (see my post above).
And, if you’re able to tell the Tablo to delete a recording via curl, are you able to edit the metadata via similar means? I’ve got some shows that have the wrong season number that I’d like to correct and I’ll be using my Tablo without a subscription, during which, I don’t think season and episode numbers are captured.
Thanks
