Woke up this morning and my Tablo had a constant pulse type of blinking going on. I reset the Router unplugged the Tablo and the hard drive and still continues to blink. Not really sure what is going on. Anyone have this problem? Thanks
Check the hard drive for errors.
How early in the morning?
If the Tablo was still accessible aka you could connect to it, but it was flashing then it was likely doing its nightly maintenance, which is does at like 3 AM unless you were recording something then. It will then do the maintenance later in the day.
Weird, I guess I do get up early. It must have been the maintenance thing, because as I returned home from work and looked at the box, all is normal again! Thanks for the replies.
