I like the Tablo TV a lot. The only thing I want it to improve is the player. The progress bar covers closed caption and makes it unreadable when you pause the play.
Closed caption is a very important feature to me. It is even more important when I try to pause the play and read it clearly. But it was covered by the annoying progress bar.
Could you move ether the bar or the caption a little bit?
I use Fire TV App FYI.
Thanks.
I believe the progress bar, when paused, disappears after a few seconds.
Also, I’ll test this out later, I believe you can make the progress bar disappear sooner, if you press the go back button.
[theuser86]: I am talking about Tablo Preview app. Just like [Radojevic] said, for OG Tablo app, the progress bar disappears after a few seconds when paused.
For an easy solution, just make the progress bar transparent will work well.
Thank you very much, [Radojevic].
Just like you said, I tested it out, the progress bar disappears when you press the go back button.
So no fix is needed. Just record this as documentation.
Thanks again, I am happy now.
