Program freezes and then gets stuck
This has started happening more frequently. The program I’m watching will freeze or buffer and then it gets stuck there and if I come back to that channel later it is still stuck on that spot…like hours later. I have to go shut the whole system down to unstick it. It’s getting very frustrating. What causes this and how can I prevent it? I use the Fire TV app.
This happens when the Tablo can’t properly process the last broadcast segment it received, so it keeps displaying the last good segment over and over again.
Typically happens when there’s a weak broadcast signal.
You’re right that the only way to get past it is to reboot your Tablo.
@TabloTV is aware of the problem.
Wish they would get engineering to fix it. :slight_smile:
So the signal the antenna is receiving? Nothing to do with my network or internet? I wonder if we try adjusting our antenna if that would help?
