I realize the difference may be minimal. But just so I know, what direction should the tablo box be facing for best wifi. I assume with the wide front portion towards the router, but of course it depends on the antenna inside the tablo box. I have the Quad OTA.
The Tablo QUAD has two WiFi antennas so the direction of the box shouldn’t matter.
Can you give guidance for the other Tablo models?
For example, I have 2 Tablo OG 4-tuner models, and 1 2-tuner.
All function via wireless.
Would love to know which direction the units should face towards the router.
