Hi Everyone. I’m brand new to the Tablo and this community and need help.
Trying to activate Tablo Connect. What #s do I need to use for the two Public Port fields?
Thanks in advance!!
Thanks in advance!!
If you use the connect process within tablo it will tell you what ports to open/use.
There are a number of solved thread (depending on your router) if you do a search on tablo connect and/or ports.
Using those numbers don’t work. I’m using the public numbers 21010 and 210211 doesn’t change anything.
@Cutter101 Hey there, we’re happy to work with you directly on this if you’re still having trouble. Just send the details to our support team.
