Playing recording fails
When playing a recorded program, it stops. I start it back up and it stops after about a minute. This repeats all the way through the program. It will not continue to play, I have to keep starting it over and over.
Are you using the internal storage, or are you using some type of external storage? If you are using external storage, what type and size is it?
Tablo recommends an external hdd with a minimum storage of 1 TB. SSD’s can be used, but there really isn’t any advantage to SSD’s and they cost considerably more than hdd’s.
Flash drives of any size are not recommended at all!
I am using the internal storage. By the way. It is a Roku T.V. Also this only happens when the recording is from my antenna. Signal strength is always good at 3-4 bars
This could be weak WiFi to the Roku TV. Do you ever get the problem when viewing OTA live?
If not, than more than likely the on-board memory is over-full or has a problem. What percentage of your on-board memory is used vs available?
Hardwire to router. OTA viewing works great. Don’t use the wifi. On board memory? Do you mean amount of dvr space? If not. Where do go to see the memory usage?
Also. My other wifi Roku tv does not this problem all recordings play back perfectly.
It can be different on different platforms. I’m not sure about Roku TV. On my external Roku devices, there is a “gas gauge” showing DVR space on the lower-left of the Library page. Also, you can go to Settings and I believe it shows storage space. I know it does for external drives and I think it does the same for the internal drive.
The DVR space has 80% available
How old is the Roku TV? The one giving you trouble.
I purchased it in July of 2024
Hmmm… well that shouldn’t be the problem.
I still think it sounds like a problem with that internal memory. If it were me, the next thing I would try is adding an external drive. Do you have a decent one laying around that you can try. It has to be between 1 - 8 Tb. Keep in mind, it will reformat the drive.
Have you talked to Tablo’s tech support?
I’m going to try to factory reset the TV and then Tablo tech support. Thanks…
Hi @Brian_Edwards1899
If you haven’t already, it may be a good idea to hold off on hard resetting before you contact support. Doing so will wipe out logs that support may find useful.
Why does one Roku tv work just fine and the other one does not?
Hi Brian,
Our Tablo logs may be able to answer that, but our support team would have to take a look to make sure.
Ok. What do you need?
I think the next step is to submit a support request. https://support.tablotv.com/hc/en-us
