If a recording records from a source with a weak signal, the playback becomes almost hard to watch and one of three things could happen:
- Recording does not download to the player fast enough resulting in a jerky playback of pause and restart every 2 seconds.
- Recording, in the middle the show, will reset and start to replace the start of the recording with what is in the middle of the show.
- Recording stops mid way through or is completely unwatchable because the signal is too weak.
I know the weak signals cannot be avoid however, the way the player reacts can be fix. As on the iOS app it seems to have no problems playing back until it reaches the weak signal section before it dies from the weak signal and that is what I want to happen.
