First time user with dual Line Tablo. I have an 8GB usb stick as my external Hard drive. I can only watch one channel with live tv. When I try and watch another channel it gives me error" Playback Failed Storage is full. Delete some recordings before trying again. I have not ever recorded anything. Do, I really need an 8TB external hard drive for this to work?
nope. But if you search the forum for usb flash drives you’ll find there are a bad idea …for technical reasons. It likely if you use a conventional drive you’ll notice an improvement.
You definitely don’t want to use a USB stick with the Tablo. That is not supported and will cause lots of problems.
You don’t need an 8 TB drive. A 1 or 2 TB drive works fine. I still have barely used 2 TB and have owned the Tablo for over 5 years (though I do clean up recordings from time to time).
If you were getting by with 8GB then 500GB is going to be enormous for your needs.
Actually it “all depends” - how many show do you archive, what recording setting do you use, length of shows, how long you store them.
As a perspective, they used to sell a Tablo Dual 64GB, advertising approx 40hrs of storage. Of course your mileage may vary. Just not an USB flash drive.
I’m using an old 750GB drive salvaged from a laptop upgrade that I put in an external drive, attached to my backup Tablo. Works fine. A 500GB drive should work find.
