Playback failed message
When i try to watch my local channels live, i get an error saying playback failed. I’ve reset the modem, Tablo & Roku & I’m still getting this message. What do I do?
Which Tablo are you using?
What error are you getting?
This sounds like you might be getting the “poor reception” message that asks you to Try Again…
I’ll add to what @269587 asked.
Are you using the internal memory or external memory?
If you are using external memory, what type is it?
Did this problem just start or have you seen this before?
