Phantom recordings - Deleted but still showing
OK, so I threw away my Zotac box because it was simply unable to give me trouble free viewing with Tablo (even though everything else I threw at the box was fine) so have switched to the following:
Table 2 Tuner - Not changed
Amazon Fire TV - Running latest version of Table App
Plex Client - With the Table add-on
I was testing out using Plex to watch my recordings as well as the Tablo app itself. I still have hiccups in both but in general Plex is better able to handle the videos (which are all recorded in 720p by the way).
On to my issue:
Watched a recording in Plex.
Deleted recording in Plex.
Recording no longer shows in Plex.
Recording no longer shows in Tablo on my phone.
Recording no longer shows in Tablo on my Macbook.
Recording no longer shows in Tablo on my daughters Roku.
Recording STILL SHOWS in the Tablo app on the Fire Tv.
The recording shows with a blank thumbnail and nothing happens if you attempt to play it.
I’m not sure if deleting the recording in Plex caused the issue or if the Tablo app on the Fire TV has an issue. I’m leaning towards the latter since all other devices do not show the phantom recording.
Darryl
Plex channel is an unsupported 3rd party app that is currently in beta. I likely wouldn’t delete from it.
Maybe the the developer @Davidvr can shed some light into this for you.
