You might want to try the one that I use. It is the Tablo passive wall-mounted cooling shelf from Closet Maid. It does not require any table space and allows for lots of airflow underneath. Easily attached to basement walls where your antenna comes in to keep your Tablos extra cool and out of sight. Enough space for two tablos, two hard drives and a network switch.
Unfortunately, I wanted my tablo next to my router, which is in the center of a 2 story house with a basement. I need the router there so it can serve all 3 floors efficiently. I suppose I could have ran an ethernet cable from the tablo in the basement to the router, but it seemed easier to use the existing coax cable run and put the tablo next to the router in my office.
Very nice setup you have though. Lots of room for the tablo to breathe.
