I’ll be mounting my Tablo under the rather large eaves on my home. This is where all the cables run into the house now, so I can get everything I need except power through existing connections.
Has anyone else tried this? I’m thinking of mounting it “vertically” against the wall and then protecting it with a tupperware container with the two long sides cut off to make a C shape that will protect it from rain and snow while still leaving the bottom open for the cables and airflow.
Sounds like a really bad idea to me. Exposing the Tablo and hard drive to exterior temps and humidity is a recipe for failure IMO. Not to mention how hard it’ll be to get to it if you need to reset it.
Finding a place for it inside shouldn’t be a big deal, really.
Unless, of course, the indoor area is far from the ideal mounting spot for the antennas, in which case you suffer signal loss. I can’t use a mast-head amp because I have some strong signals that will overwhelm the weaker ones in that case.
Yes! However I was kind of looking forward to seeing a picture of a Tablo mounted under the eaves. Would have been a unique landmark…and now everyone has been trying to dissuade him.
Can you imagine if a bird built a nest there? MM could tell tech support, “Hey my Tablo laid an egg.”
“Hey, Big Bird, stretch your wing all the way out… ok… ok… now just a little bit down…ok ok… tilt your head just a little,…noo… too much, there… STOP!.. perfect…”
