You got a Shield? I believe if you configure a button on the Harmony remote to replicate the right trigger on the Shield controller, it will be a 30 second fast forward. I’m not sure if that’s an option.
Yes, I ended up getting the Shield and it is amazing. Thanks for the heads up on the controller. I think I need to just sit and write out what each button does. Do you know if there is a guide that shows the buttons for the nvidia controller in the tablo app?
Yes, there is. Go to the Tablo app, then go to the side main menu, and hit “Help”. I was blown away when I found this after a couple of weeks.
I heart you
Thanks a ton.
Set it up at lunch and it works great. I even set up different skip aheads with the fast forward and okay sequence to let it play again. Now if only I had a button mapped to Live TV, Recorded TV, etc.
That would be awesome! I think you can map out chained button presses, but I haven’t ever bothered to go into that much detail other than starting and stopping activities (turning off and on all devices and setting to correct inputs).
