Hello all! I’m thinking of cutting the cord permanently and trying different streaming services. I use an Nvidia Shield which has been great! I want to be able to record shows, but does the tablo have to be connected to an OTA antenna or can it just be connected to the shield and record what it’s streaming?
The Tablo will only record shows from an OTA antenna.
You might want to participate in the Tablo Engine Beta program with your Nvidia Shield.
The Playlater software (http://playon.tv) will allow you to record streaming services you have subscriptions for. Windows PC required. Then you can side load the playon android app on the Shield. Or use VLC to play from a network share.
Thank you all for the responses, I’ll look at the playlater software and Tablo Engine beta program!
