I have been able to get the app installed and my recordings work great on my window 8 table using chrome, Ipad works great, also works great from my Chromebook.
I have seen the same issue with that model. I am guessing it is not tested and supported on that old hardware. My suggestion remains to clarify what hardware is supported and also mark the app as not supported on that hardware in the Roku store so it is not available to confuse customers.
FWIW, it works fine on newer Rokus.
That makes sense what you are saying. I will be sure to find out how to mark my model as not supported.
I am also having trouble getting my Chromecast to work as well with Tablo with Load Failed when it tries to cast the recording. I can play my recordings on my Chromebook, Window 8 Tablet with Chrome and my IPAD. Just can not seem to get it to play a recording on my TV. Chromecast works great with Youtube and Netflix and webpages.
If you have Plex the XD/S can play back recorded programs. It still can’t do live tv though.
@Ramseyerp @vgrund is correct here. We’ve tested and confirmed the latest generation of Rokus, including the Roku 2, 3 and the HDMI stick (though the WiFi antenna on it can be flaky) - for other models, we’re still trying to get of a hold of a few, but it can prove difficult with the older generations of the Roku.
That solved my problem. Plex on my Roku and works great.
