Table has been working fine for months and all of the sudden I don’t get sound with live TV, all channels. All other apps and recorded Tablo shows do have sound. I’m using Firestick to stream Tablo. Other TVs in the house have sound with Live TV, just not the main one that Tablo is hooked up to.
I tried unplugging, deleting and reinstalling, turning off surround sound all with no luck.
Turn off surround sound and then reboot your Tablo aka power cycle it.
It worked! Thanks.
FWIW - If you switch to the Tablo Preview app for that Fire TV stick, you should be able to view Tablo content in Surround Sound:
Didn’t realize there was a difference on this, thanks for the heads-up.
