I have tried the web app and the iOS app on my iPhone 6 with iOS 8.1. When I click on LiveTV and choose a show from the guide my only options are Rec or Rec All. There is no Info button and there is no Play button. Ideas? The 1GB drive attached has been formatted.
On smartphones, you have to click on the station, not the show, to get it to play.
Ahhhhhh haaaaaaaaa! Thank you
No problem. I think it gets about everyone the first time they try to watch live tv on their phone. :)
You were watching me then?
It’s that way when using a PC, too.
Just takes getting used to is all.
On a PC with Chrome, you can click on the station, but you can also click on the show. All shows have a play button (as well as a record button), and if you press play, it will play whatever is current on that station.
