"No hard drive connected" message, no recording playback, but can rewind live TV
My Tablo is reporting “No hard drive connected”. I can’t play recordings, but can see them, and CAN pause and rewind live TV. My hard drive is a 2TB WD Elements and my Tablo version is 2.2.6. I have used the Tablo with this drive for over a year without this issue. It seems if the drive was bad I wouldn’t be able to pause and rewind live TV.
Hi @Scott_Solgot - It’s possible your hard drive may need a firmware update (from WD). We can check on that for you if you’d like: http://bit.ly/1w8BrBw
Sure. It’s a WDBU6Y0020BK-05.
