Hi,
Channel 33-1 WNNE is a CW-affiliated television station broadcasting in Montpelier, Vermont. Can you add the guide info for it?
Cheers,
Dean
Hi,
Cheers,
Dean
Hey there @Deanerama - The best way to get this fixed is to send a note to our support team so they can start the process for you: www.tablotv.com/ask-tablo
Make sure to include the zip code you used to set up your Tablo.
