I use the tablo tunner with tablo engine on my nvidia shield and i got no audio.
No audio, only image for live tv and recorded shows.
I used it without problems for a while, stoped using it for a couple months and now it’s not working anymore… i tried the bypass suround on and off without succes.
Then you might want to log a call with Tablo Support. I only tested surround sound when it first came out. It did not work with my Nvidia shield so I turned it off and have never tried it again. I believe this affects the recordings. So did you try live TV with it off? Or a new recording recorded with it off? .
Well I missed the whole tablo engine part Ignore what I said earlier, I was thinking TabloTV not Tablo Engine… I have the surround sound bypass on in the Tablo Engine and have no issues on a Nvidia Shield. So if you have not done so yet log a support call.
Yes, everything updated and double checked many many times…
Tired of trying to fix this and waitings days and days to get help from support.
I decided to buy an hauppage tunner and installing Plex… and wow! Everythings works fine now and im happy with this solution.
