I have an older 4-tuner Tablo (rectangle shape Tablo - connects over WiFi with no HDMI available; external hard drive attached). Firmware version: 2.2.38. I have commercial skip on my Android devices when I am connected to the home WiFi. I don’t have commercial skip when connecting remotely.
The Tablo app on my Android used to skip commercials when connecting remotely even though it did not show the yellow highlights for commercials in the timeline. I don’t know exactly when it stopped, but I first noticed that it stopped skipping commercials a couple of weeks ago (I only occasionally connect remotely). I don’t know if I lost my commercial skip after a recent firmware upgrade or not.
I tried uninstalling and reinstalling the Android Tablo app, and that didn’t help.
Is there anything I can try to get commercial skip working again when connecting remotely?
I have this same issue.
When my mobile app is connected on local network with the Tablo 4 tuner, commercial skip works. When I turn off my wifi on my phone and connect remotely, commercial detection yellow lines no longer show up.
It worked until very recently.
I’m having this same issue. On my mobile device the commercial skip is turned on, but the yellow detection skip areas only show up when device is connected to same local network as the tablo.
I’ve noticed both my iOS & Android apps just recently stopped showing commercial detection yellow lines.
Commercial skip works fine on locally connected Roku and Android devices.
