Please provide details about your network setup. What is the IP address of the tablo (server host from settings). What is the IP address of the PC. What is the IP address if the IPAD. The wireless access point and the tablo and the PC need to be in the same subnet.
I was just able to access the Tablo using the Tablo Ripper, pointing to 192.168.1.17, but when I try to connect from my PC at my.tablotv.com (using Edge), I get this message: A connection to your Tablo could not be established. Please check your internet connection.
MS Edge browser currently doesn’t work with the Tablo.
Depending on the Tablo firmware version, and Mozilla Firefox version, they won’t work together either, although, I can use Firefox to connect to my Tablo right now.
However, an update on the Tablo firmware, or Firefox could break that.
Google Chrome is one of the main web browsers they designed the Tablo to work with.
I don’t think @Radojevic is the one who was wrong once… when he thought he make a mistake - but he genuinely helps out. I guess almost everyone does, even if it’s “IDK, why don’t you try…”
