Just got one and started testing it with my Tablo. When a show is selected from the Recordings list, and I get the show screen, the highlighted control is the Delete button. Accidentally hitting OK/Select at that point is a really bad thing. I have to hit the down button to get to the episode list. I think the default should be to show the episode list.
Besides that, I’m really not happy with no hardwired ethernet and requiring additional hardwire to make it work with a universal IR remote (Harmony). Also, can’t seem to reorder the apps so Tablo is way at the end of the list. Probably going to return it and just stick with Roku or AppleTV. I’m holding off on buying more Rokus until I see the AppleTV app.
Overall, the experience on Android TV has been far better for me than on the Roku. Some things to help. On the guide use the play/pause button to start playing and you can avoid the delete button.
I use WiFi without issues on my Nexus Player, but you can get a simple adapter for Ethernet support. The shield has support for IR (I believe), and you can use an IR remote if your TV supports HDMI-CEC without use of the Hub.
Lastly, make sure that the Nexus Player is updated to Marshmallow and then pick an app, press and hold the select button and it will bring you to the screen that will let you organize the apps.
I don’t use my TV remote. I use a Harmony. And I’m not convinced CEC will work with a TV, AV Receiver, and Streaming box all in the mix. Haven’t tried it yet. Anyone gotten CEC to work in that scenario?
