Hey Tablo Fans!
We’ve just pushed out an update for all Tablo Dual LITEs. This update is available now. We highly recommend processing this update as soon as possible.
This update will resolve any issues you were experiencing accessing existing recordings from the Tablo Cloud DVR or uploading new recordings.
If your Tablo app isn’t prompting you to update, you can receive the prompt for the update by tapping the blue reset button on the back of your Tablo to reboot it.
Once your Tablo is back online, reconnect to it and you should be prompted with the 2.2.23 firmware update.
Release Notes for Tablo Firmware 2.2.23
- Cloud DVR fix REQUIRED for customers using Cloud DVR feature: enable new recordings and access old recordings.
That’s all!
