I can’t seem to get this going on my new iMac. Tablo Exporter immediately says 100% (but says status is exporting. Not sure if it’s actually doing anything though).
I can’t seem to get ffmpeg put in the right place to execute the line command version above
Can someone (at the very least) give me basic instruction to install ffmpeg in the right place with the right permissions based on the fact it’s a brand new system and no usr/bin directories exist? For some reason I must be missing something.
Thanks!
I’m really asking for next steps. I have ffmpeg - I need to put it somewhere, right? Are you able to help me with a step-by-step process so that I could use command lines like I posted originally to convert files? THANK YOU!
You downloaded the source NOT the static file, Unless you plan on building the executable yourself you need to download the static file as I described.
Then you extract it, point Tablo Export to the ffmpeg executable file.
