Hi @eek,
What devices do you use with your Tablo? Try updating your firmware through one of their Tablo apps.
Hi @eek,
the website only.
you fixed it a few days later.
I have the same question. Will the new features be available on HDMI legacy DVRs?
Doesnât show when I do check for updatesâŚso not quite available for all just yet. we have HDMI tablo
As stated in the first post of this thread, HDMI Tablos are not included in this firmware update, so you will not receive this update.
Hi there,
since it seems we have an HDMI, Iâm left perplexed as to why Tablo sent us an email telling us to update urgently when Tablo knows full well what model we have and that it did not apply to us.
What a waste of your time and mine!
BTW the About info on the device settings menu doesnât actually say anywhere what model it is, you have to intuit it from the side menu which in our case says âDisplay more information about your Tablo HDMIâ when you hover over âMore informationâ and if you click on that âmore information â it has
About
Restart
Status
network and other information
Under which it has the ip address and the up time
So from that I figured we had a plain HDMI since thereâs zero mention in the info of âdualâ or âquadâ
Now that I go to untangle the wires and turn over the box I see on the bottom that itâs actually Dual HDMI
So the about info is somewhat POOR.
Sigh!
I guess they thought the truth was self evident since only HDMI models have a HDMI connector on the back panel and a remote.
For the issue were legacy Roku appsâ guide shows all sporting events showing up as diagonal bars, try toggling the 14-day live TV Grid option OFF and ON in SETTINGS.
I donât want a 14 day live grid. It doesnât work on older roku ultras. I donât use the live TV grid to schedule anything. I usually check the Live TV grid to determine if any of todays scheduled recordings are either actually recording or scheduled to record or I missed a sports event to record..
This coupled with the change to extend live have caused me to move more important recorded sports events to plex.
I have been checking my tablo updates available under settings. It shows version 2.2.42 but when I check for updates, it says that I have the most recent update
I believe all this was explained, for confirmation
I have 2 Tablo Duo Liteâs in storage, for backup maybe. So unless I dig these out, connected and configured before May 22, Iâll never be able to update them?
Do you have a network connected Tablo or is yourâs an HDMI connected Tablo? If itâs an HDMI connected Tablo it is not eligible for this firmware update. However, if you have a network connected Tablo, I would contact Tablo Support to get their help in updating your Tablo.
