The auto delete is only when space is needed?
@mb190e - Yes. When your hard drive is nearing fullness, your Tablo will delete the oldest unprotected recordings so there’s space for the upcoming scheduled recordings.
Why after upgrade all my channels in settings show no bars?
@TabloTV thanks. And it was awesome seeing my picture in the email announcing the update.
You’re welcome! And you made a wonderful model :)
No, you shouldn’t have to. We’ll look into it and let you know.
How long should the resync take? Mine’s been going for 45 minutes now…
Stuttering is still present in the Android phone running 4.4.4 version of KitKat.
Arrgh! Can’t try any of it 'cause my Tablo is still resynching… going on an hour now…
You may want to just disconnect, delete, and then re-add your Tablo, @Flatulator. I had to do that to get my web app to work right.
Apparently just my luck to get my 4-tuner today. It just says “Connecting” and nothing else happens…I really hope this is related to the new firmware release and not a problem with my new Tablo.
Finally! It wouldn’t sync from a hard-wired Chrome connection, but no problems via iPhone and wi-fi. Go figure.
I have the same missing bars for the signal strength on my channels after the update. The channels work fine in live tv. Forcing a rescan just sits there and does nothing for 2+ minutes so I exited the scan.
@byb I know this is completely unhelpful in your case but I had the same problem after the update. Went back to Channel Lineup and did a re-scan and it worked perfectly. Have you power cycled?
Is there a way to delete an entire season of a show in one fell swoop, or is this for a subsequent release?
Love the darker look and new icon for the Roku. This is much easier on the eyes. Also the new resume feature is great tested it on a few shows on the Roku and everything is working.
Love my Tablo! Keep the updates coming, this thing is awesome.
@brikim the closed captioning coming on when hitting the left arrow is by design with Roku. You can change this by going into Settings / Captions / Captions Mode and turn it off, by default it is set to Instant Replay. You can always turn them on later if you want with the * button
