I purchased a Keedox® M8 Amlogic S802 Quad Core Cortex A9 2.0GHz Bluetooth 2.4G/5G Dual Wifi XBMC/Kodi Streaming Player 4K Hdmi Android 4.4 KitKat OS TV Box With Remote Control.I have downloaded android tv app ,but does not appear to work correctly.I am still learning but would like to make sure Tablo is compatible with this device.Thanks
@ncwaterman - We haven’t tested that particular device but it seems to be running a supportable version of the Android O/S.
Send a note over to support w/ further details including what you’re seeing on the device so we can see what’s wrong: http://support.tablotv.com/hc/en-us/requests/new
Thank You. I will keep playing to see if I did something wrong.Its the only way I will learn this android stuff.
