I’ve b3en using it since it was released.
Glad to hear it is still in good use!! There are a few functions with using external players that suffer under newer versions of Android (where they’ve changed file permissions quite drastically) but the main use case is still going strong
@lkahhan unfortunately, the API that Tablo makes available to 3rd party apps is only available on the local network, so you must “load up” your ota2go with downloads while in the same spot as your Tablo. It is possible to do some advanced stuff like setting up a VPN between your phone and your router to get you on the same subnet from outside, but it is generally hard to do and is rife with security risks which are hardly worth it for reruns of Barney Miller in my opinion lol!
Happy Holidays!
@sctaylor That’s right. I do remember now. Ah well, I’ll make sure to load up before I go.
