Is there any resolution to changing wifi networks without having iOS. The article says to contact support if you can’t switch WIFI networks. All they did is send me a reply with the same direction that indicate it only works with iOS.
Pretty amazing isn’t it. I’ve been trying to do this for 3 years on what then was a new samsung tablet running android 12.
Yeah, it was suppost to be “coming soon” in 2023. Unbelievable.
I had to buy a used iPhone to fix this issue. It’s only a SE iPhone and got it for 75 dollars. I figure I can use it for a backup phone for my up coming 30 day international trip. It sucks that I had to do this but I didn’t want to lose my videos already recorded. It’s bizarre to me that Tablo wouldn’t have a easy work around for this other than buying an iPhone.
An old SE for cheap was a good move.
Unfortunately there are other products with apps out there that work on Android or IOS but not both. That is pretty dumb but it is what it is.
Anymore I check system requirements before I buy anything that has an app.
The setup problem I had in 2023 was that the only device I had that had both WiFi 2.4 and 5 was a new’ish Samsung running android 12. No matter what tricks I tried the tablo setup failed with the notorious “unknown” error while collecting the SSID’s. After around 10+ tries I had to use a device that only had 2.4 WiFi.
I figured tablo would eventually add edit WiFi to the android app. Wrong again.
My problem was the installation of a Eero 7 wifi router connected to the Tablo wifi via 5G. Previously it connected to the old router at 2.4G. On 5G it buffered all the time so I had to connect it to another 2.4G network with a different name so it would work.
When I dropped CenturyLink DSL and went 5G home Internet I was initially disappointed with the router/gateway lacking fundamental settings that I always found useful then smiled when I saw it supported a 2.4 GHz IoT network.
That made it easy to get 2.4 GHz hardware like Tablo and home automation devices to reliably connect and stay connected.
In their zeal to provide the least expensive hardware 5G home internet providers are creating problems that third party hardware manufacturers can’t and won’t be able to address.
Before you jump on 5G home internet look at the hardware REALLY carefully to make sure it will allow you to do what you need.
It seems that some of these wifi problems can be avoided by connecting the Tablo Gen4 to ethernet, if the router has a port.
For sure…
