Can I use my web browser outside my network to access my tablo? For instance during lunch at work to be able to schedule recordings?
yes. But make sure you have the device connected to it by wifi atleast once.
Specifically, you must access your Tablo on your home network using the the PC/Device you intend to use at work before your able to access it outside of your home network using that PC/Device.
Yes you can, web app on a PC, tablet or smartphone will remotely connect to Tablo as long as you “pair” it to the Tablo by connecting once while on the local/home network.
OK, thanks all!
