Everything is working fine except there’s no guide info. I’ve refreshed and rebooted and nothing.
Working fine here
Mine is working fine also.
Have you tried any other devices (phone or tablet)?
Did you reboot both your Tablo and your playback device?
You might try deleting the Tablo app from your playback device and then reinstall it.
In the Tablo app you might try disconnecting from your Tablo and then click the red X to remove your Tablo from your playback device app, then search for your Tablo and connect to it again. It may take several minutes to hours to download all of the information again, depending on the number of stations you have selected and your internet speed.
Just like that - my guide is blank — something else is broke… you’re just the first to notice and make a post.
If you’d provide a bit more info, you might get some assistance with your guide outage.
1 station (4-1 but oddly not 4-2 or 4-3) was blank for me for a couple weeks so I decided to rescan today and now all of the guide is blank. I have also disconnected and reconnected on multiple devices, rebooted the tablo, and hit the update now on the guide. Seems to sit at 0% forever and if I navigate away after a couple minutes and back it says it was updated at wherever time I started it.
EDIT: I reset all of the DNS caching on the router and the guide started downloading after hitting update now.
