Multiview ports during fast forwarding
I really appreciate that tablo had fixed the single viewport back to multiview ports when fast forwarding. But I would also have a request to make it even better, when I pause and look at the screen now there is the volume control bar right dead center of the screen plus options to put on closed captioning on or off, can this be moved down to the bottom of the screen? when we pause for sports or the news or whatever we want to view the volume control bar is in the way. Thanks John
Hi @John_m_Sprofera ,
Would you be able to DM us a screen capture?
It’s possible you’re seeing the seek bar rather than a volume bar, but we would like to be sure.
You are correct, but it would be nice if it was down towards the bottom of the screen rather than towards the middle, but that’s just me.
Thanks for letting me suggest. Enjoying my Tablo, John :backhand_index_pointing_down:
I would like to have a way to clear that progress bar when paused. I think that the BACK button on my Roku used to clear it, but it no longer does.
