r multiple rokus possible
yes. You mean using multiple Rokus on the same LAN with one Tablo? Definitely.
1 Roku connecting to 1 Tablo works.
1 Roku connecting to multiple Tablos works.
Multiple Rokus connecting to 1 Tablo works.
Multiple Rokus connecting to multiple Tablos works.
Of course, each Roku can connect to 1 Tablo at a time, but they can disconnect, and connect to a different one if you have multiple Tablos.
Same thing for other hardware, and you can have any kind of mix up to all channels / streams being used. If you are buying now, I would highly suggest the Mi box for a better Tablo experience. Roku’s have had more problems off and on, and is why I first got the Nexus Player. After Google dropped it, I got the newest Android TV box and like it better than the NP.
