I have a 4ch Tablo and I have the Tablo apps installed on 2 Amazon Fire TV devices, and 2 Amazon Fire Sticks.
On the 2 Fire Sticks, they show 6 shows recorded.
On the 2 Fire TVs, each show only 5 shows recorded. But, only 4 of these shows are the same on both devices. One Fire TV has a show called Classical Stretch on it, and the other has Intellegence For Life on it. (But the one with the Classical Stretch on it shows a #3 on it’s image while there are actually 4 shows recorded under it.)
The 2 Fire Sticks showing the correct 6 shows recorded has the correct #4 on their Classical Stretch recordings image.
I have tried restarting the Fire TV’s but that doesn’t change the recorded shows displayed.
I have tried disconnecting and reconnecting to the Tablo but the recorded shows still do not change.
At some time on one of the Fire TV’s, I had deleted a recording and the other Fire TV did update correctly removing the deleted show from it’s display.
I just can’t figure out why or how to correct the displays so that both of the Fire TV’s are showing the correct recorded shows from the Tablo.
