Are you looking at New shows under the Prime Time tab or are you looking for New shows under the TV shows tab?
There does appear to be a bug in the prime time tab, at least for me in central time zone. 7-10 PM should be prime time for my area, but it is only showing 8-11 PM shows.
I see both your shows only under the TV shows tab.
Thanks! That appears to be it. I had clicked All, but that was still All under the Prime Time main header. They do show up in the TV Shows main header.
