Important points, both devices need to be on the same firmware. You need to tap the blue button on the old device! This creates the backup DB (feature request, this should be done routinely for the unfortunate failure). When the drive is connected to a new device, it will detect the DB and “restore” it and be up and almost pretty much ready to go.
Unless you formatted your drive, you didn’t loose anything. If the new device didn’t “take”, you should be able to go back to the first device – there should have been no reason anything changed onboard.
In my experience, if you stop the process before it completes, even though it takes several hours if you have a large database, there is no recovery. I did the same thing once and was told there was no way to get the recordings back. I later tested the process with about 3.5TB of recordings and it took almost 8 HOURS, (not minutes as the knowledgebase article says) but after that, it DID work fine. I suggested they change the knowledge base article to say that a large database will take HOURS to complete but the last time I looked at it, they had not changed it.
I’ll be interested if they can help get the recordings back because I was told, “If you stopped the process while the LED was still pulsing, there gone”…
Yes, both have the same firmware. Yesterday it seemed to be working but (pulsing LED for almost 5 hours) but I had to go to bed (it was a bit late) and I read that I shouldn’t leave it like that otherwise the nightly maintenance routine could wipe the whole disk. So I stopped the process. This morning I tried to do it again but the mistake I did was to connect the drive to the new Tablo before powering it up. So it seems like the new Tablo overwrited the DB because after trying to play my recordings with my new Tablo and failing, I tried to connect the drive back to the old Tablo and it also couldn’t play my recordings. The good news is that in the settings I see the drive has still 3TB of data so I assume my recordings are still there and that I just need to find a way to recover them. I’ll ask Tablo Support for help just in case. Otherwise I’ll connect it to my Ubuntu desktop or my Mac Mini and try to convert the files to mp4 somehow. Maybe MCEBuddy can convert them (it should be relatively simple to tranfer them to my Windows desktop).
OK! So probably Tablo Support will tell me same (that my recordings are gone). I’ll write them just in case and see. I tried to trigger the process again but it just took minutes (after my mistake of plugging the drive to the new tablo before powering it on, and also after factory resetting the new Tablo again to be sure it’s clean) and now the recorgins are not readable by both Tablos (even the old one). So at this point I think I lost my original database which was related to my recordings so I would need the Tablo to build a database or to recover it somehow from a “recycle bin” but I don’t know how to do that. My linux/terminal knowledge is very limited. I’ll let you know if I get a solution to recover my recordings.
Tablo Support answered my request and told me to try it again and put my device in “remote access mode” (3 quick blue button clicks). I called them and they checked and triggered the recovery process. It took some hours and now I have all my 3TB of recordings back! I’m so glad they fixed it!
So now I can confirm it’s worth asking Tablo Support for help if having problems migrating your recordings to a new Tablo.
PLEASE NOTE: If you run into any issues with the transfer and can’t get it to work, make sure the drive doesn’t remain plugged in to the new Tablo overnight - when Tablo does its nightly maintenance, the drive may get formatted. Just remove the drive and give us a call during support hours for a hand.
Great to read positive feedback for tablo support
never really believed you "lost" everything, this has got to be so much easier than the path you were on... look at as a learning experience. I bet you have a greater understanding how your tablo works!
Im not sure cause I don’t know if tech support triggered the migration right after we talked on the phone or later. If the process started after the call and finished when I checked, it took about 3 to 4 hours for about 2.5TB of data. That seems shorter than what others have observed. Maybe since I tried last week and stopped the process after about 4 hours, the job was partially done?
If I was to start another migration of 3TB I would expect to wait for at least 8 hours.
