The Tablo audio output is lower than all other devices attached to the TV. The volume level is about 50% lower than everything else. An audio level adjustment feature would be great. Thanks
Do you have the surround sound feature turned on? It is under the main Settings in the Tablo app. Try that.
The reason for my suggestion is with the surround sound turned on the Tablo records the native AC3 audio stream and there is no conversion. So essentially the audio is untouched.
When it is off, the audio is converted from 5.1 AC3 to 2.0 AAC.
Thanks for your response. The surround setting does help, not a total fix but better than it was. Thanks again!
