I have two antennae (different headings) with inline amplifiers
combined to one output (with a DC blocker coupler) connected to a 3’ cable. I connect this array directly to the TV
(single tuner) and my signal strength is strong for all the channels I want to watch.
When I connect the antenna set-up to the Tablo, several of the channels have pixilation
and the Tablo repeatedly buffers, i.e., I get “loading, please wait” message. Not knowing if another amplifier would improve
the 4-Tuner Tablo, I plugged the antenna arrangement to the wall antenna outlet
which feeds to the network closet where there is a 4 port Channel Master
Distribution Amplifier feeding other locations in the home. I retest the Tablo connecting directly into
the Channel Master’s output, and get the same results of pixilation and
buffering on a nearby Roku (hardwired) TV.
I connect a TV directly to the antenna outlet in another room furthest
away from the network closet and there is no pixilation on any of the channels
that I watch (the TV’s diagnostic shows strong signal strength). On this same
TV, I have a Roku (hardwired) and test out the Tablo stations and the results
are not good (as to be expected). I
realize that you lose DBs with the 4-tuner, but I thought the Tablo’s built in
amplifier is supposed to help with this loss?
Would a different kind of amplifier help the Tablo’s performance,
perhaps one with a higher boost in DBs?
<w:LatentStyles DefLockedState=“false” DefUnhideWhenUsed=“true”
DefSemiHidden=“true” DefQFormat=“false” DefPriority=“99”
LatentStyleCount=“267”>
<w:LsdException Locked=“false” Priority=“0” SemiHidden=“false”
UnhideWhenUsed=“false” QFormat=“true” Name=“Normal”/>
<w:LsdException Locked=“false” Priority=“9” SemiHidden=“false”
UnhideWhenUsed=“false” QFormat=“true” Name=“heading 1”/>
<w:LsdException Locked=“false” Priority=“9” QFormat=“true” Name=“heading 2”/>
<w:LsdException Locked=“false” Priority=“9” QFormat=“true” Name=“heading 3”/>
<w:LsdException Locked=“false” Priority=“9” QFormat=“true” Name=“heading 4”/>
<w:LsdException Locked=“false” Priority=“9” QFormat=“true” Name=“heading 5”/>
<w:LsdException Locked=“false” Priority=“9” QFormat=“true” Name=“heading 6”/>
<w:LsdException Locked=“false” Priority=“9” QFormat=“true” Name=“heading 7”/>
<w:LsdException Locked=“false” Priority=“9” QFormat=“true” Name=“heading 8”/>
<w:LsdException Locked=“false” Priority=“9” QFormat=“true” Name=“heading 9”/>
<w:LsdException Locked=“false” Priority=“39” Name=“toc 1”/>
<w:LsdException Locked=“false” Priority=“39” Name=“toc 2”/>
<w:LsdException Locked=“false” Priority=“39” Name=“toc 3”/>
<w:LsdException Locked=“false” Priority=“39” Name=“toc 4”/>
<w:LsdException Locked=“false” Priority=“39” Name=“toc 5”/>
<w:LsdException Locked=“false” Priority=“39” Name=“toc 6”/>
<w:LsdException Locked=“false” Priority=“39” Name=“toc 7”/>
<w:LsdException Locked=“false” Priority=“39” Name=“toc 8”/>
<w:LsdException Locked=“false” Priority=“39” Name=“toc 9”/>
<w:LsdException Locked=“false” Priority=“35” QFormat=“true” Name=“caption”/>
<w:LsdException Locked=“false” Priority=“10” SemiHidden=“false”
UnhideWhenUsed=“false” QFormat=“true” Name=“Title”/>
<w:LsdException Locked=“false” Priority=“1” Name=“Default Paragraph Font”/>
<w:LsdException Locked=“false” Priority=“11” SemiHidden=“false”
UnhideWhenUsed=“false” QFormat=“true” Name=“Subtitle”/>
<w:LsdException Locked=“false” Priority=“22” SemiHidden=“false”
UnhideWhenUsed=“false” QFormat=“true” Name=“Strong”/>
<w:LsdException Locked=“false” Priority=“20” SemiHidden=“false”
UnhideWhenUsed=“false” QFormat=“true” Name=“Emphasis”/>
<w:LsdException Locked=“false” Priority=“59” SemiHidden=“false”
UnhideWhenUsed=“false” Name=“Table Grid”/>
<w:LsdException Locked=“false” UnhideWhenUsed=“false” Name=“Placeholder Text”/>
<w:LsdException Locked=“false” Priority=“1” SemiHidden=“false”
UnhideWhenUsed=“false” QFormat=“true” Name=“No Spacing”/>
<w:LsdException Locked=“false” Priority=“60” SemiHidden=“false”
UnhideWhenUsed=“false” Name=“Light Shading”/>
<w:LsdException Locked=“false” Priority=“61” SemiHidden=“false”
UnhideWhenUsed=“false” Name=“Light List”/>
<w:LsdException Locked=“false” Priority=“62” SemiHidden=“false”
UnhideWhenUsed=“false” Name=“Light Grid”/>
<w:LsdException Locked=“false” Priority=“63” SemiHidden=“false”
UnhideWhenUsed=“false” Name=“Medium Shading 1”/>
<w:LsdException Locked=“false” Priority=“64” SemiHidden=“false”
UnhideWhenUsed=“false” Name=“Medium Shading 2”/>
<w:LsdException Locked=“false” Priority=“65” SemiHidden=“false”
UnhideWhenUsed=“false” Name=“Medium List 1”/>
<w:LsdException Locked=“false” Priority=“66” SemiHidden=“false”
UnhideWhenUsed=“false” Name=“Medium List 2”/>
<w:LsdException Locked=“false” Priority=“67” SemiHidden=“false”
UnhideWhenUsed=“false” Name=“Medium Grid 1”/>
<w:LsdException Locked=“false” Priority=“68” SemiHidden=“false”
UnhideWhenUsed=“false” Name=“Medium Grid 2”/>
<w:LsdException Locked=“false” Priority=“69” SemiHidden=“false”
UnhideWhenUsed=“false” Name=“Medium Grid 3”/>
<w:LsdException Locked=“false” Priority=“70” SemiHidden=“false”
UnhideWhenUsed=“false” Name=“Dark List”/>
<w:LsdException Locked=“false” Priority=“71” SemiHidden=“false”
UnhideWhenUsed=“false” Name=“Colorful Shading”/>
<w:LsdException Locked=“false” Priority=“72” SemiHidden=“false”
UnhideWhenUsed=“false” Name=“Colorful List”/>
<w:LsdException Locked=“false” Priority=“73” SemiHidden=“false”
UnhideWhenUsed=“false” Name=“Colorful Grid”/>
UnhideWhenUsed=“false” Name=“Light Shading Accent 1”/>
UnhideWhenUsed=“false” Name=“Light List Accent 1”/>
UnhideWhenUsed=“false” Name=“Light Grid Accent 1”/>
UnhideWhenUsed=“false” Name=“Medium Shading 1 Accent 1”/>
UnhideWhenUsed=“false” Name=“Medium Shading 2 Accent 1”/>
UnhideWhenUsed=“false” Name=“Medium List 1 Accent 1”/>
<w:LsdException Locked=“false” UnhideWhenUsed=“false” Name=“Revision”/>
<w:LsdException Locked=“false” Priority=“34” SemiHidden=“false”
UnhideWhenUsed=“false” QFormat=“true” Name=“List Paragraph”/>
<w:LsdException Locked=“false” Priority=“29” SemiHidden=“false”
UnhideWhenUsed=“false” QFormat=“true” Name=“Quote”/>
<w:LsdException Locked=“false” Priority=“30” SemiHidden=“false”
UnhideWhenUsed=“false” QFormat=“true” Name=“Intense Quote”/>
UnhideWhenUsed=“false” Name=“Medium List 2 Accent 1”/>
UnhideWhenUsed=“false” Name=“Medium Grid 1 Accent 1”/>
UnhideWhenUsed=“false” Name=“Medium Grid 2 Accent 1”/>
UnhideWhenUsed=“false” Name=“Medium Grid 3 Accent 1”/>
UnhideWhenUsed=“false” Name=“Dark List Accent 1”/>
UnhideWhenUsed=“false” Name=“Colorful Shading Accent 1”/>
UnhideWhenUsed=“false” Name=“Colorful List Accent 1”/>
UnhideWhenUsed=“false” Name=“Colorful Grid Accent 1”/>
UnhideWhenUsed=“false” Name=“Light Shading Accent 2”/>
UnhideWhenUsed=“false” Name=“Light List Accent 2”/>
UnhideWhenUsed=“false” Name=“Light Grid Accent 2”/>
UnhideWhenUsed=“false” Name=“Medium Shading 1 Accent 2”/>
UnhideWhenUsed=“false” Name=“Medium Shading 2 Accent 2”/>
UnhideWhenUsed=“false” Name=“Medium List 1 Accent 2”/>
UnhideWhenUsed=“false” Name=“Medium List 2 Accent 2”/>
UnhideWhenUsed=“false” Name=“Medium Grid 1 Accent 2”/>
UnhideWhenUsed=“false” Name=“Medium Grid 2 Accent 2”/>
UnhideWhenUsed=“false” Name=“Medium Grid 3 Accent 2”/>
UnhideWhenUsed=“false” Name=“Dark List Accent 2”/>
UnhideWhenUsed=“false” Name=“Colorful Shading Accent 2”/>
UnhideWhenUsed=“false” Name=“Colorful List Accent 2”/>
UnhideWhenUsed=“false” Name=“Colorful Grid Accent 2”/>
UnhideWhenUsed=“false” Name=“Light Shading Accent 3”/>
UnhideWhenUsed=“false” Name=“Light List Accent 3”/>
UnhideWhenUsed=“false” Name=“Light Grid Accent 3”/>
UnhideWhenUsed=“false” Name=“Medium Shading 1 Accent 3”/>
UnhideWhenUsed=“false” Name=“Medium Shading 2 Accent 3”/>
UnhideWhenUsed=“false” Name=“Medium List 1 Accent 3”/>
UnhideWhenUsed=“false” Name=“Medium List 2 Accent 3”/>
UnhideWhenUsed=“false” Name=“Medium Grid 1 Accent 3”/>
UnhideWhenUsed=“false” Name=“Medium Grid 2 Accent 3”/>
UnhideWhenUsed=“false” Name=“Medium Grid 3 Accent 3”/>
UnhideWhenUsed=“false” Name=“Dark List Accent 3”/>
UnhideWhenUsed=“false” Name=“Colorful Shading Accent 3”/>
UnhideWhenUsed=“false” Name=“Colorful List Accent 3”/>
UnhideWhenUsed=“false” Name=“Colorful Grid Accent 3”/>
UnhideWhenUsed=“false” Name=“Light Shading Accent 4”/>
UnhideWhenUsed=“false” Name=“Light List Accent 4”/>
UnhideWhenUsed=“false” Name=“Light Grid Accent 4”/>
UnhideWhenUsed=“false” Name=“Medium Shading 1 Accent 4”/>
UnhideWhenUsed=“false” Name=“Medium Shading 2 Accent 4”/>
UnhideWhenUsed=“false” Name=“Medium List 1 Accent 4”/>
UnhideWhenUsed=“false” Name=“Medium List 2 Accent 4”/>
UnhideWhenUsed=“false” Name=“Medium Grid 1 Accent 4”/>
UnhideWhenUsed=“false” Name=“Medium Grid 2 Accent 4”/>
UnhideWhenUsed=“false” Name=“Medium Grid 3 Accent 4”/>
UnhideWhenUsed=“false” Name=“Dark List Accent 4”/>
UnhideWhenUsed=“false” Name=“Colorful Shading Accent 4”/>
UnhideWhenUsed=“false” Name=“Colorful List Accent 4”/>
UnhideWhenUsed=“false” Name=“Colorful Grid Accent 4”/>
UnhideWhenUsed=“false” Name=“Light Shading Accent 5”/>
UnhideWhenUsed=“false” Name=“Light List Accent 5”/>
UnhideWhenUsed=“false” Name=“Light Grid Accent 5”/>
UnhideWhenUsed=“false” Name=“Medium Shading 1 Accent 5”/>
UnhideWhenUsed=“false” Name=“Medium Shading 2 Accent 5”/>
UnhideWhenUsed=“false” Name=“Medium List 1 Accent 5”/>
UnhideWhenUsed=“false” Name=“Medium List 2 Accent 5”/>
UnhideWhenUsed=“false” Name=“Medium Grid 1 Accent 5”/>
UnhideWhenUsed=“false” Name=“Medium Grid 2 Accent 5”/>
UnhideWhenUsed=“false” Name=“Medium Grid 3 Accent 5”/>
UnhideWhenUsed=“false” Name=“Dark List Accent 5”/>
UnhideWhenUsed=“false” Name=“Colorful Shading Accent 5”/>
UnhideWhenUsed=“false” Name=“Colorful List Accent 5”/>
UnhideWhenUsed=“false” Name=“Colorful Grid Accent 5”/>
UnhideWhenUsed=“false” Name=“Light Shading Accent 6”/>
UnhideWhenUsed=“false” Name=“Light List Accent 6”/>
UnhideWhenUsed=“false” Name=“Light Grid Accent 6”/>
UnhideWhenUsed=“false” Name=“Medium Shading 1 Accent 6”/>
UnhideWhenUsed=“false” Name=“Medium Shading 2 Accent 6”/>
UnhideWhenUsed=“false” Name=“Medium List 1 Accent 6”/>
UnhideWhenUsed=“false” Name=“Medium List 2 Accent 6”/>
UnhideWhenUsed=“false” Name=“Medium Grid 1 Accent 6”/>
UnhideWhenUsed=“false” Name=“Medium Grid 2 Accent 6”/>
UnhideWhenUsed=“false” Name=“Medium Grid 3 Accent 6”/>
UnhideWhenUsed=“false” Name=“Dark List Accent 6”/>
UnhideWhenUsed=“false” Name=“Colorful Shading Accent 6”/>
UnhideWhenUsed=“false” Name=“Colorful List Accent 6”/>
UnhideWhenUsed=“false” Name=“Colorful Grid Accent 6”/>
<w:LsdException Locked=“false” Priority=“19” SemiHidden=“false”
UnhideWhenUsed=“false” QFormat=“true” Name=“Subtle Emphasis”/>
<w:LsdException Locked=“false” Priority=“21” SemiHidden=“false”
UnhideWhenUsed=“false” QFormat=“true” Name=“Intense Emphasis”/>
<w:LsdException Locked=“false” Priority=“31” SemiHidden=“false”
UnhideWhenUsed=“false” QFormat=“true” Name=“Subtle Reference”/>
<w:LsdException Locked=“false” Priority=“32” SemiHidden=“false”
UnhideWhenUsed=“false” QFormat=“true” Name=“Intense Reference”/>
<w:LsdException Locked=“false” Priority=“33” SemiHidden=“false”
UnhideWhenUsed=“false” QFormat=“true” Name=“Book Title”/>
<w:LsdException Locked=“false” Priority=“37” Name=“Bibliography”/>
<w:LsdException Locked=“false” Priority=“39” QFormat=“true” Name=“TOC Heading”/>
</w:LatentStyles>
<![endif]–><!–[if gte mso 10]>
/* Style Definitions */
table.MsoNormalTable
{mso-style-name:"Table Normal";
mso-tstyle-rowband-size:0;
mso-tstyle-colband-size:0;
mso-style-noshow:yes;
mso-style-priority:99;
mso-style-parent:"";
mso-padding-alt:0in 5.4pt 0in 5.4pt;
mso-para-margin:0in;
mso-para-margin-bottom:.0001pt;
mso-pagination:widow-orphan;
font-size:11.0pt;
font-family:"Calibri","sans-serif";
mso-ascii-font-family:Calibri;
mso-ascii-theme-font:minor-latin;
mso-hansi-font-family:Calibri;
mso-hansi-theme-font:minor-latin;}
<![endif]–>
I’m not an employee but I have a question,
if you plugged your coax from the antenna to a 4 way splitter and then into your tv, do you experience similar degredation of quality?
As I understand it, the tablo acts as a splitter. When I try to use 4, my signal is not strong enough (not using pre amps). I can only use the two tuner.
Just a thought.
@millsdm
Your question is a valid one. I’m fortunate to have a small TV I can move
around, that generates a signal strength meter. So, when I look at the TV after
going through only the 4-way splitter (Channel Master) the reception and signal
strength are good. (Keep in mind, the Channel Master 4 Way splitter has a built
in amplifier.)
I found that the Tablo is very sensitive to marginal loss of
signal strength. I retested the antennae
directly to the TV, adjusting the direction of the antennae to maximize and
improve signal strength for those channels that were pixelating on the Tablo. The results were positive. I also have the
Tablo connected to the antenna after the Channel Master Distribution Amplifier. I am very happy with the reception through
the Tablo for Live TV and recordings now.
</w:LatentStyles>
font-size:11.0pt;
<![endif]–>
