local channels are gone and I have no favorites, I have reset and rescan removed power for 10 min, nothing works. Any ideas what is causing this?
Could it be your TV antenna connection? It may have somehow gotten loose or something’s happened with the antenna itself.
Try disconnecting it and reconnecting it,just to be safe. Then run another channel scan.
My OTA channels fail to show up every now and then. I switched to category view and they were there. They were still there when I switched back to channels view. It doesn’t happen often.
My antenna is on a splitter and goes to the TV as well as the TABLO, the TV has all the OTA channels. I did two more resets, and the last one finally showed all my OTA channels. Now this is going to bug me, just waiting for it to happen again.
Thank you guys for your help.
Glad it’s working. Let us know if it happens again.
