I have had my Tablo 4 tuner for almost 3 month. Over the last 1.5 weeks, I have noticed that when I watch live TV or a recorded show, that I am getting the Loading message. The weird thing is it is hit and miss. It is not constant. My settings for Max Recording is the HD720 - 3 Mbps.
I am using a Roku Ultra with the Tablo App on it to view my OTA channels. I also have a WD Elements 4TB USB hard drive.
My roku is hard wired in and my Tablo is connecting to my home network over WiFi at the 2.4GHz band. I did notice on my router that my 2.4GHz band had the mode configured to be Up To 217 Mbps.
When I did my channel scan, all my channels came in with the green dot so I am assuming that means great signal strength.
So, my questions are:
Does my HD play into the fact that I am getting the loading message?
Would I be better served with an SSD hard drive for better performance? Assuming that the laoding message is due to my hard drive and the buffering it is doing
Should I change my Tablo to connect to my 5.0 GHz band?
I am at a loss as to why I am getting the loading message.
I have also opened up a support ticket with Tablo to try to get their perspective. I also figured I would post here to see what some of the long time cord cutters had to say.
The other issue here is the Roku - Roku has a nasty habit of using WiFi Direct between the Roku and its remote on the very same band as your home WiFi and at a higher amplitude than the native signal. I’m damned if I can figure out what the Roku thinking behind this is, but it’s well documented and cause terrible interference with WiFi on the 2.4 GHz band.
