Watching live TV on an iPad, with a wired Tablo and very good WiFi reception on the iPad, Live TV freezes after a few minutes, and then never resumes. The display freezes and the little whirly thing just spins forever.
This is real similar to what’s happening to me with the Apple TV and recorded shows. I haven’t tried it with live TV because I have my antenna wire directly to all my TVs I only use the Tablo to record.
@Prabbit - Try updating the firmware on your Apple TV and rebooting. This solves 90% of issues with Apple TV and is a simple fix. @mb190e 's issue seems a bit different and we’ll work to find out the solution and share it.
Hi Tablo, I’m not using an Apple TV yet–the freeze issue occurs on an iPad. Doesn’t occur with a PC-based web browser, but the iPad freezes every time. Running latest iOS7 updates, of course.
@Prabbit - Ah sorry, that is definitely not expected and not what we’re seeing here. Can you please place a ticket w/ support to let them know? Please tell them what type of iPad you’re using.
Will do, thanks!
Quick update: This issue was fully resolved by rebooting the iPad. Crazy, it was just live TV that was messed up. Memo to self: Reboot everything often and frequently.
Help! I run Tablo thru Roku. I also have screens freezing, then drops to loading bar. The live T.V. loads, starts playing for a minute or two then repeats this all over. Any help, thanks
